Options for mounting spare in HMMWV bed
riderdan
20
Central Kansas
I've not added an airlift rear bumper (yet) to my humvee, so at the moment my spare is just laying flat in the "bed" of my four-man soft top truck. However, that 160lb wheel and tire could be an unwelcome intruder into the cabin should I have to stop hard (currently it's tied to the tailgate latches to keep it from shifting).
When I was in the service, I don't recall that we ever had a spare in the truck--but that could just be my bad memory. In any case, I'm thinking about mounting the wheel/tire in the bed so I don't have to worry about it. I'm interested in hearing what others have done to keep the spare in place: horizontal Y-straps, upright chock brackets, whatever. Pictures would be especially appreciated.
Lawdog734
53
Colbert, GA
I use the Special Forces Tire carrier in mine - they're fabricated items. The pic below is an example, but mine is minted to the side of the bed.
Wire Fox
161
Indianapolis, Indiana
If you want it to lay flat, there's a bunch of generic systems on the internet that use a three webbing straps, coming together in the center, to hold down the tire. They come with bed-mount brackets that you could drill the bed to lock in place. You could probably fab up something on your own for dirt cheap. Another solution would be to grab a LoadTamer cargo net that attaches to all the tie-down points in the bed of the HMMWV and use that to hold onto the wheel....but I'd want to check it against the manufacturer first to see if they think it'll hold a wheel in-place.
I have one of these nets and they seem to be built darn-tough, but I never thought to use one to hold a wheel down before now.
riderdan
20
Central Kansas
Thanks for the pic. Did you reinforce the bed somehow, or just bolt it through with washers? I'm still amazed by how heavy the wheels are (with run flats in them) so I'm curious... Also, did you mount it on the driver's side near the cab for better rear visibility?
riderdan
20
Central Kansas
I've seen some of those y-strap deals around, but the "normal" ones don't see to be big enough to get around the 37" tires. I suppose I could check an offroad supplier since they're more likely to have something that would fit these whopping big tires. I've thought about just mounting one of those truck-bed spare tire mounts to the inside of the bed, but because of the weight and the relative thinness of the aluminum, I'm reluctant...
Action
1,555
East Tennessee
I have the real bed net that hooks to the loops in the bed. I can throw a tire in the bad and take a pic if you want. They are green.
juanprado
2,829
Metairie/La (N'awlins)
just fyi, They do make a 4 man bulkhead and brackets if you want a solid partition to protect the cab. Ebay has the partitions and I just saw a fellow member offering the brackets here on ss 86humv
I would think laying down and ratchet strapped across 2 of the tie downs would keep it in place.
ryanruck
45
Cincinnati, OH
I can't take credit for the idea and, I'm still in the process of prepping mine for installation but, maybe consider installing some E-Track in your bed to secure the tire to.
Some pics I've stolen from the guy that did think of it:
You can either strap down the tire with E-Track D-Rings like this:
Or, places like Northern Tool have specific E-Track spare tire holder attachments but I don't know if the E-Track ends up being high up enough to use them.
I think I'd want 2 of those though given the weight of these tires.
I'm doing mine a little differently. I'm going with two rows of E-Track, top and bottom. Also, I'm doing mine for cargo control since I've got a Rhino for my spare but, I could always secure a second tire back there if I wanted. It adds a lot of versatility.
Action
1,555
East Tennessee
That pic in the post above this one....That tire looks like it can just tip over the top of the fender. The one strap is attached at almost the top of the fender, and the center of the tire is well above the fender. Also that strap is below the center of the tire.
ryanruck
45
Cincinnati, OH
Yeah, I had similar thoughts when I saw it but chalked it up more to being a proof of concept shot since he and his buddy had just finished putting it all in.
If I were mounting a tire in said fashion I'd use 2, or possibly 3, ratchet straps. At minimum two through the hub of the wheel to either side of the tire and, maybe for extra security, one over the top in a similar manner to prevent, like you said, the tire from coming up.
Bravojmc
Palisade, Colorado
View attachment 680484 View attachment 680485
Guys.... I'm a former firefighter and this spare setup is a disaster waiting to happen... I was the first person to arrive on a scene. What happened was a family turned there truck over and the 75lb tool box wasn't strapped down and the box itself was what killed the mother (35) and daughter (5).... I still to this date wake up from nightmares of that scene. PLEASE PLEASE find a better way to tie this spare/gear down... Not trying to be a bummer but....
ari
dacula Ga
I did the same only instead of doing to rows I mounted em in the middle its low enough to keep the tire from moving around and high enough to strap fuel cans or whatever else to the side. I wouldent quite trust that wheel standing up in the bed I can see it falling out especially off roading, I looked at the spare tire mount and it looks kinda weak and by the looks of it i dont think there is a way to use 2 of them and have the holes line up. I got the e tracks from northern tool for $15 each if anyone else is looking. IMAG0726.jpgIMAG0718.jpg
Lawdog734
53
Colbert, GA
I mounted it to the bed floor and the fender wall using large washers and 3/8" bolts. It's very secure.
As for location, I thought I had one saved (hence the earlier pic), but apparently don't. I have it currently mounted to the passenger side, but will be moving it soon. See, the carrier is notched for that spot that sticks up in the 90 degree bend of the floor and fender wall. With a partition in place, it wouldn't mount correctly, so I it put it on the passenger side - but now visibility out my right rear stinks. I'll remove it soon and have a new notch cut so that I can mount it appropriately on the drivers side, where my rear visibility won't be as badly affected.
The pic below is how my truck is set up, I just need to reposition my tire from the passenger side.
riderdan
20
Central Kansas
Thanks for the info. That's kind of what I was thinking of. I suspect that if I mount the spare hanging off the back I won't be able to get the truck to fit in our garage. I have my welding kit and tool boxes along the front wall, so it's already a kind of tight fit.
On an unrelated note, I gotta ask: where did you get those sides? They look like cut down troop seats... very nice.
ryanruck
45
Cincinnati, OH
Those are GMV bed rails. There's those and some tube style ones Mil Sys Group makes. If you find any like the ones above, let me know. I need them. :mrgreen:
I got a set of repro corner posts that 86humv has had from another member who didn't need them but I'm waiting for a set of the rails to turn up or find something comparable commercially that will work in their place.
bob smith
McKinney,TX
If you run with the thought of when you have a rel flat on the run flat and you are going to have to replace or fix the tire, why not remove the run flat and go with a tube and save the weight? is this not an option?
Wire Fox
161
Run flat gets you out of dodge/allows the vehicle to handle reasonably well if a sudden blowout occurs. The best option, runflat or not, is to pull over immediately and change the tire to prevent further damage and possibly get to salvage your damaged tire. I also personally don't know how a tube would handle in this application...seems like there's a lot of risk for high friction and overheating, plus I don't know the load bearing standards tubes might have (if they're even made for this tire size). I come from the land of dual-sport motorcycling, where tubes vs tubeless is a very real and strong debate, so I get where you're coming from...
