Guruman
Not so new member
- 494
- 1,076
- 93
- Cody, Wyoming
So, I've been on a journey to get my winch and a/C installed.
Made a big move yesterday and got the options panel and the interior A/C unit installed. Not too much in the way of difficulties, but my options panel is not working. (All is well with the A/C unit)
The options panel has two sets of connectors. A short set that obviously connect to two empty connectors behind the heater unit. They are keyed so that you cannot hook them up incorrectly, and they won't reach anywhere else. So I'm pretty sure those are correct.
The other set, run under the passenger side kick panel and contain plugs labeled P210 and J108. P210 goes to my winch harness, and J108 seems to be for the dump bed options, so it's not connected anywhere.
The issue:
The switch lighting in the options panel does not work. None of them. Leading me to believe it might be a connection or ground issue.
Also, the tach does not operate. This could be related, or I might be the sensor needs adjustment or replacement. I have not had the time to look into that just yet.
And... I populated all of the switch holes with switches, just to fill the blanks, and for future use. At least one of the switches causes a relay to activate I the PDP. So something is working...
I know I've seen a thread on this with a similar issue, but a site search and a site specific search engine search turned up nothing useful, so maybe I read it elsewhere.
Any ideas on what to check?
The issue:
