- 2,660
- 8,587
- 113
- Alexandria, La
All-
Kind of at a bump in the road.
What did the original Blinker lights that were here look like and where can I find them?
On my headlights, I have 3 wires, 17, 18 and 19 with female connectors.
On the harness side, I only have 17 and 18 and they are both female connectors.
According to Vintage, these are their uses:
17: Dimmer switch high beam to left headlight, right headlights and high beam indicator.
Now, I **do** have 3 male connectors on the harness:
Wires 20, 491 and 460J. According to the instructions from Vintage, those are
20: Headlight switch connector to left and right blackout marker lights
491: Light switch connector to left and right headlights
460J: Flasher relay (J) to right headlights.
Does 17, 18 and 91 from the headlight connect to 20, 491 and 460J? That's the way the connectors lay out.
Any help is appreciated.
I called Vintage and they didn't answer and their mailbox is full
