Oshkosh MK14
Mingler
seattle wa
Hey Gang, does anyone know if my M-923 can pull a Oshkosh MK14 trailer. I want to put a cargo container on it. do they hook up the same....is the height ok???
Shawn
[h=1][/h]
MWMULES
344
DESOTO, KANSAS
Short answer, if it looks like this, No mnk19.jpe unless you have the issued or have fab'd a tow bar attachment. #8 . If it looks like that and you will have to spend more money and time you can make it so your 923 can haul it an empty 16,000 lbs trailer. If it was me I would look for another trailer like a M1061 but if you are using a 20' container it won't work, too short only 14'.
sandcobra164
287
Leesburg, GA
I have pulled them with the Deuce in the past, I am sure the M923 would be more than happy with the task. Airlines and trailer lights hook up the same and it tows slightly nose down. The Deuce had 11R20s at the time. In the attached pictures, you will see a Deuce hauling an MK-18 trailer which would likely weigh about the same as an MK-14 trailer with a 20 foot ISO on it. In the second picture, you will see I had way to much time on my hands one afternoon and I connected 3 MK-14 trailers together. The Deuce moved them but the rear two had the brakes caged. Member PCTrans made a camper out of the exact setup you are describing. He put gutted 5 ton axles underneath it to lower the weight a decent amount.
