Our MTVR camper:
MTVR
761
Waco Texas
It actually dipped below freezing last night, and even though we haven't foamed the gaps, our own body heat alone was almost enough to keep us warm. We had a tiny little 750-watt heater in there, but we kept having to turn it down and turn it off to keep us from sweating...
MTVR
761
Waco Texas
We spent the night in it again last night, and this time we didn't use any heat. Once again, it dipped below freezing, and once again, we stayed warm enough...
MTVR
761
Waco Texas
Foamed the drawbridge insulation today:
We hope to trim the cured foam and glue and screw the outer plywood on tomorrow.
The drawbridge is several steps behind the rest of the structure, and we want to get it as done as we can before moving to Texas. After doing the outer plywood, we still have to epoxy it inside and out, drill and mount the hinge, drill and mount the spare tire carrier, prep it for paint, paint it, and source and install the weatherstripping...
MTVR
761
Waco Texas
Trimmed the cured foam today, and sheathed the outside of the drawbridge with 3/4" plywood, screwed and glued with urethane construction adhesive...20201029_143316.jpg
MTVR
761
Waco Texas
We also layed down the first coat of epoxy on the floor inside today.
We plan to lay down the second coat of epoxy on the floor tomorrow.
And we plan to do a little prep work on the outside of the drawbridge and then paint it.
MTVR
761
Waco Texas
Put down the second coat of epoxy on the floor, did a reasonable amount of prep work on the drawbridge, and then let my wife paint it...
MTVR
761
Waco Texas
Drawbridge weatherstripping showed up.
We also picked up the nuts, bolts, and washers to mount the drawbridge hinge.
Hoping the weather will give us an opportunity to mount the drawbridge hinge over the next couple of days.
Once the drawbridge hinge is mounted, we can start road testing the vehicle and changing the gear oil in the planetary hubs.
We're only about two weeks from moving to Texas...
MTVR
761
Waco Texas
The drawbridge is mounted! I tested it afterwards by sitting on it in a folding chair and having a beer.
That was a big step for us. We were thankful that it worked correctly on the first try.
We still have a little work to do on it, to include installing the weatherstripping, but we ran it up and down about ten times, and it works perfectly... :)20201108_122010.jpg20201108_142315.jpg20201108_155918.jpg20201108_112740.jpgResized_20201108_160216.jpeg
MTVR
761
Waco Texas
It is getting harder and harder to get anything done outside, because of the weather. It's been raining and/or below freezing, and is going to continue doing that. A lot of the things that we're using (paint, urethane, epoxy, silicone) won't set up in those conditions.
Today is the only day before we move that is predicted to be dry. It's not going to be above freezing until about 0900, today's high will be about 40 or so, and sunset is before 5:00 pm.
MTVR
761
Waco Texas
First road test went VERY well. Everything worked, from the lights, to the wipers and washers, to the adjustable Jake brake. We put about 10 miles on her, including cruising up and down the freeway at 55 mph. Planetary gear hub temps all in the mid-90s, tire temps all about 70 degrees, all dash gauge readings good.. :)
Nomadic
80
Nevada
Looking good! Nice work.
The drawbridge is a good idea. It seems to expand the real estate quite a bit while extended.
What is the interior height?
