HeavyArms
- 1
- 3
- Charleston,SC
I am converting my 7k to use axles from the 12k trucks. initially i got the pinion gears. from a 12k to swap on for the axle shaft and i have the Diff stub flanges with smaller Diam ring. well i got a chance to buy grab a full set of out drive Helical cut gears from a REV truck. Does any one know if these are all the same ratio? the straight cut pinion has 13 teeth and the helical cut has 12 teeth. i haven't counted the straight cut driven gear yet. Also will i need to buy the axle stubs for the 12k? or are they all the same spline 7k-10k-12k. Thank you in advance.
![20230130_125417.jpg 20230130_125417.jpg](https://www.steelsoldiers.com/data/attachments/645/645218-a5e142367050ab2f1bcb6ae96b7e3bba.jpg)
![20230130_124624.jpg 20230130_124624.jpg](https://www.steelsoldiers.com/data/attachments/645/645216-83d1a30613f45b8fa5845c3204feb3ca.jpg)
![20230130_124555.jpg 20230130_124555.jpg](https://www.steelsoldiers.com/data/attachments/645/645217-45185f7e1785522d2d675ca10363ebc8.jpg)
