out drive Helical cut gears vs straight cut
HeavyArms
Charleston,SC
I am converting my 7k to use axles from the 12k trucks. initially i got the pinion gears. from a 12k to swap on for the axle shaft and i have the Diff stub flanges with smaller Diam ring. well i got a chance to buy grab a full set of out drive Helical cut gears from a REV truck. Does any one know if these are all the same ratio? the straight cut pinion has 13 teeth and the helical cut has 12 teeth. i haven't counted the straight cut driven gear yet. Also will i need to buy the axle stubs for the 12k? or are they all the same spline 7k-10k-12k. Thank you in advance.
86humv
539
Texas
Stub shafts have all the same splines....the stub shafts in pic : Left one is for solid 12k rotors....Right is 7, 10, 12k vented rotors.
