Ouverson Lock outs HEAVY DUTY SEALED 575 bucks!!
hot rod deuce
Kasota, Mn
the remco has to be able to hold the same TQ as the 1410 joint right? you would think the engineers would have made it that way. What is there to not be heavy duty enough? the outer spline is 3 inches across so it only needs to be 1/3 the stregth as the 1" (1/1/4?) slip yoke right? as for the shifter part, it might be a little exposed but i plan on making my own air shift anyway.
Also i dont plan on turning the rear axle at all on longer voyages so mine needs to be able to handle 2200+OD
IM GOING TO EBAY!!
hot rod deuce
Kasota, Mn
HAHA yeah i saw thay right after i said i was going to look. Thats too small for sure. I guess that that 1410 series is a little more rare. Maybe anything with a 1410 is too big to tow behind an RV?
rmgill
14
Decatur, Ga
If one of you makes one of these, I'd bet you could make more and sell them to us regularly. I know I'd start budgeting for one.
readyman
Elk Grove Village, Illinois
HRD, rdixiemiller, rmgill,
Here is the basic concept using the original interaxle(2). A full 3 inch spline engagement on both ends. That'l hold.
Seems like there is a engineered 3-1/2 spline travel on the original. But the wear marks show only about a 1/2 inch travel.
Does anybody know how much the interaxle splined joint travels during rear axle movement? I have to 'design in' some clearance(like in the third picture) when the axles move.
spicergear
Millerstown, PA
As far as movement of the axle and it's compression of that jackshaft...I'd think that on flat ground the shaft is going to be as compressed as it's going to. Any movement up or down of either axle, or both, is going to have the slip yoke pulling apart. The only time I can figure that they'd be any closer would be if the truck was jacked up and both rears were off the ground the suspension links would pull them together. So, that being said...if the truck is jacked up you got other problems and the only other time that might happen is if the truck were to be jumped. Heh,heh...I don't think the jackshaft would be the biggest worry then-
