Oval thingy below the bed
dirtyfingernails
Gainesville, FL
I have a silly question. What's the steel oval ring welded below the bed and between the two rear axles do? It's on all of the vehicles, but I never see anything attached to them. Thanks.
Steve
Jetnoise400
Sparks, NV
Steve,
That ring is part of a sling system. There is a large bar that goes through that ring (the end points upward with a closed ring at the end), down between the axles on top of the spring mounts and attaches to that bracket looking thing on top of the suspension... I'm looking for a photo, I just saw one... stay tuned.....
maddawg308
821
Appomattox, VA
How come I've only seen one deuce in many years of my involvement in the MV hobby with this sling bar installed? Are they rare?
emmado22
168
Mid Hudson Valley NY
I never seen saw one in the Army... No one knew what they were REALLY for, we used used them for a ratchet strap tiedown point.
rmgill
14
Decatur, Ga
The only time they'd really be used is for loading the trucks onto shops. They're probably a General Support end use item for the big logistics folks and most likely only seen sitting way in the back of a particular parts truck. With RO-RO the rule of thumb now for ship loading it's doubtful they EVER Get used.
FrankUSMC
33
Newport, NC
I saw several trucks with the lifting bars in place while in the Marines. I am still kicking myself because there were several of the them on the trucks my friend cut up back in January. I did find one of the lifting bars in the pile of scrape and I gave it to Garbee.
One of the few, Frank
1,827
GL just released a bunch about a year ago. When they loaded all the 900 series trucks here at Port Everglades they didn't use them. I believe Bruce Kalin has them on his deuce. Bruce is the founder of the East Coast Convoy.
jasonjc
289
Gravette Ar.
I neve seen them in use either even when I helped load out the 1CAV DIV on the way home (1 st go round) Some trucks did go on top of the ro-ros.
This must be the replacement look close it hard to see in this pic
JDToumanian
15
Phelan, CA
Sorry for the poor quality, but here's a pic of one of the lifting bars that fit there... The top end not visible due to the over exposure, loops over to form a lifting ring.
Regards,
Jon
