coachgeo
- 3,379
- 113
- North of Cincy OH
for improved MPG....
Not being full-time 4wd would help fuel milage also I would think.
I don't know if such animals (overdrive / cascade box) exist that would mate up to the CAT or either end Allison transmission, nor if a divorced Tcase exist that could take torque of the CAT etc.
* Say a two or three ratio Gear box stuffed in there. Miight even get you a lower AND higher ratio out of tranny. Best of both worlds?
NOTE- Took this above quote and made this new thread so not to hijack the thread the above quote was found in.
makes since if all one wants is a more roadable higher MPG rig. Not though if you want to have capable off road abilities as well. Looks to me (and I've not looked REAL close) is potential better route to go may be to stuff an overdrive or 2cnd gear box* in there somewhere between engine and tranny or tranny and T Case. For example, remove T case and install overdrive there then put a divorced T Case with High (1:1) and low ratio. Either it a 2cnd gear box or just overdrive you'll end up with a more traditional 4x4 set up instead of full time 4wd..... not a good or bad thing... just a different thing, BUT you do end up with both better ratio for 4x4ing AND for off roading.I've heard rumors of 1.75 reduction gears at the hubs and I've been trying to track a set down. The 3116 [CAT engine] needs to be spinning ~1800pm for best fuel consumption. I've also pursuing a reduction hub eliminator kit which would get cruise rpm to that range, but not sure how well that will work.
