overpressure pop off quick fix.
Floridianson
2,526
Interlachen Fl.
Mine was leaking on the wet tank just a bit so I took it apart. There is spring and a steel ball that sits on brass seat. The ball was pitted from water on one side. I put it back together and it still leaked. I air up the tank and used a pair of plyers and pulled up on the pin and let the ball dance around abit then let it snap shut. It's holding for now and when it leaks again I will replace it. My .02
doghead
4 Star General /Moderator
1,191
NY
Maybe a new stainless steel ball would be a good improvement.
Floridianson
2,526
Interlachen Fl.
Thanks Chris it's ok for now. Darn thing did not starts leaking intill the PPV valve went bad. Owell it's good for now and I found the correct part # on an old thread.
