packing pellets in my new turbo...
jesusgatos
on the road - in CA right now
As long as you do not remove the turbine or compressor, all is fine. Nothing special about the housing to snails gaskets.
So there are gaskets that I'll need to replace? By the way, I think I already mentioned this, but it's is a D-series turbo.
If there were something FUBAR about the turbo, I'd take it apart and fix it. That little peanut won't hurt a thing. I have seen rags go through turbos and not hurt them on both the compressor and turbine sides. If you believe the peanut is an issue, take the housing off and clean it out. They are very easy to do, and, Yes I would run it!
BTW, what kind of cat is that? Is it real? It looks cool, yet scary at the same time. My Niece saw it and said she has never seen one and she works at the Humane Society!
Yeah, I've heard that (about rags). Impressive. I'm mostly worried about them melting and gumming things up. Kinda leading towards taking the housing off. Maybe taking a little time to port-match and blend the intake. I gotta find out if there's anything else that makes sense to do while I've got it out/apart.
No idea on that cat. To tell the truth, I'm not much of a cat person. I just found that picture online (looking for ugly cats). Jesus Gatos = Jesse Katz (that's my name).
I'd say take it apart and make sure no peanuts are left in there. As is they probably wouldn't do much harm; but heated up and melted, they can stick to the turbine wheels which definately will lead to balance problems.
Taking the compressor and turbine housings off is not a big deal-- just a matter removing clamp(s) or bolts and retainers and lifting the housing off. You get into trouble when you start trying to take the cartridge (center section) apart. Do one side at a time so you can set the turbo down on the end with the housing still attached.
The exhaust side may take a little convincing due to heating and rust build-up.
If you don't already have a favorite-- a good solvent is heat riser cleaner, the stuff you squirt on an older car's exhaust manifold heat riser to free it up.
Shouldn't take much more than a lead or brass hammer. Make sure the housing comes off evenly all the way around. Tolerances are tight and you don't want to bend the tip of a compressor of turbine blade. Remember, some of the smaller turbos will spin up to around 100,000 rpm and at that speed it doesn't take much to throw them off balance.
Once you're sure all the foreign stuff is cleaned out; take a look around the inside. You're looking for rub marks where the turbine or compressor wheel has been rubbing against the inside of the housing.
Oily inside means a seal is leaking. Get these replaced as the engine will and sometimes does run on after shut-down 'cause it's sucking up and burning the crank-case oil. If the leak is bad enough the engine can run away and the only way to shut it down is to suffocate it with a board across the inlet (don't bother with a rag-- there's enough inlet air flow to simply take the rag away from you, inhale it and wrap it around the air filter).
And that's after / if you've been successful in wrestling the mushroom off.
A spooky proposition even if you're half expecting it.
If everything looks good then reassemble the turbo and check your shaft play.
To check side play; try to push the shaft tip side to side. .003" to .006" is acceptable. If you don't have a dial indicator, a feeler gauge will work between blade and housing.
Push the shaft away from you and measure the larger gap, pull the shaft towards you and measure the same gap again. Divide the difference by two and that'll be your side play from .000" centered to the maximum.
I've had them with a lot more and as long as they're not scraping against the inside of the housing they seem to work. It's still a good idea to rebuild one this worn far.
Check for end play by pushing the shaft in and out of the turbo. Allowable here is .001" to .003".
This really should be measured with something pretty true and accurate-- instead of relying on the "Well, it-looked-OK-to-me" method. Remember, .003" is the thickness of one sheet of paper.
Thanks for taking the time to write such a helpful post! This turbo looks like it's in great shape. I would guess that it's 'almost new'. But I'll definitely check everything that you mentioned.
Jones
Sacramento, California
I haven't had a multifuel turbo apart in a while but my Cummins 5.9 turbos don't use gaskets in the housing to cartridge fit. Only gaskets on them are a stamped stainless steel gasket between the turbine housing and the waste-gate cover and one for the turbo to exhaust manifold connection.
1,182
Maybe try a heatgun or hairdryer and see if you can melt/shrink the peanuts without making a mess.
randyscycle
Rhoadesville VA (where!)
Spray them with a shot of 2+2 or other carb cleaner in an aerosol can. They will dissolve so completely you won't know they were ever there. Follow that with a shot or two of WD40 just for good measure afterward.
I wouldn't take the turbo apart for a little bit of styrofoam.
Capt.Marion
15
Atlanta, GA
Take a packing peanut or two, and drop one in water, and another in acetone. Then you'll see which solvent you need to use to dissolve the ones remaining in your turbo. I say this because it is nigh on impossible to tell a water-soluble/starch-based peanut from the traditional styrofoam ones with the naked eye.
stampy
22
Henderson. NC
Agreed with above melt those suckers (with water or acetone), you may do more damage taking the turbo apart, Also may void any warranty you have.
Keith_J
1,325
Schertz TX
Oh, it is easy. Polystyrene are usually "S" shaped or tubular in a figure 8 cross section, cut on the bias. But starch ones are cylindrical, like a Cheeto, except with square ends.
