Padlock key? And transfercase seal part#
ryan77
56
Cary IL
My m1009 has a padlock with us on it where the spare would go does anyone have a key for these i can copy or should i cut it off??????????? On another note does any one have a napa part# for the drive shaft seal on the transfer case????
whatsagoodalias
Virginia Beach, VA
I looked it up on Napa Online for 85 K5 blazer with 208 transfer case. 18992 is the number for the rear seal and 18771 for the front. As far as the key is concerned, I would cut the padlock.
Crash_AF
Colorado Springs, CO
Call a locksmith and ask how much to rekey the lock if you want to keep it. Otherwise cut it off as there is no common key for those padlocks.
Later,
Joe
jeffhuey1n
SMSgt, USAF (Ret.)
1,475
Laramie County, Wyoming
I have two on my deuce. I talked to a lock smith about the very same thing. Simply put, if it has a number such as a 4 or 5 digit one, they can re-key. I have one they can re-key because it has the code. The other hasn't got any numbers. I'll re-key the one, hope the key works on the other and go from there.
papercu
31
Baxley, Ga.
If you do cut there was/is a guy in the classifieds that was wanting any cut padlocks and/or extra keys for the military locks. Wayne
zyrtecx
Western NC
If the lock is an American, you can grind down the little shinny metal tab on the bottom of the lock carefully and remove the oval metal piece holding the cylinder in and just have a locksmith install a new cylinder and retaining nut and plate and nut on the bottom of the lock and then you will have a usable lock with "US" stamped in it. Also, the Govt. lock, locks key and not be removed with the lock open, only when it is locked...
