Paint job
Predator42
Pleasant Grove Utah
Thanks. I like how it turned out as well. Total cost was about $400. This is a paint and primer in one. It takes some getting used to, so do a test panel. You get one shot because you can't wet sand or buff out this type of paint. The hood is the most difficult. I had never painted with satin before so I was taking a big risk. I just took my time, painted it on my driveway early in the mornings before full sun. Took about 15 cans to complete. These cans have a nice fan spray pattern so I just overlapped each wet line making sure no dry spots were left. I ended up having to paint the hood 3 times before I got it acceptable. Anyway fwiw.
Retiredwarhorses
4,625
Brentwood, Calif
The hood is the hardest....I usually have to apply 2-3 times before I get it covered just right. Any bare spot, even primed well just sucks up the paint and shows a light spot. That's why the epoxy primer works best....IMHO.
Predator42
Pleasant Grove Utah
Whats the story on the rear bar/canopy you got going on? Some kinda different soft top go over that?
The rear canopy/rack is designed to hold my kayak and give the truck a wagon look. I haven't decided what to cover it with. Ambulance top was too tall for my liking and would have required I use just that top. I will either skin it in metal, aluminum or canvas. I need to make sure it functions as I want it to so its in the R&D phase right now. I like the side access and the utility of strapping ratchet ties to it so I am not entirely sure if I want to add some loops and skin it or what. My goal is to get it water tight and holding heat for the winter as well as make something a lot more secure, so I think the canvas Idea is out.
Predator42
Pleasant Grove Utah
That's a spray can job?!? Wow looks good.
Thanks 941038. Yes it is a spray can job. I had never done a satin paint before so I am glad I got the results I did. I will say it looks good from afar, but far from good when up close. but that was my sheer lack of proper surface prep since this paint shows all flaws. for what it is though, it worked out.
tomelroy
88
Morgan, UT
you can sand blast aluminum at low psi with some media without warping, but if you remove the alodine coating, either by sand blasting or hand sanding, make sure you prime before you paint.. Paint doesn't stick to bare aluminum.
Retiredwarhorses
4,625
Brentwood, Calif
Of course you can...but you don't want too. You will regret it. Chemical strip....treat it like an airplane.
aluminum starts to oxidize immediately if not treated. And I can almost guarantee you that you would find a shop that can acid wash and alodine and entire truck.
rhinob
Ijamsville, MD
"Of course you can...but you don't want too. You will regret it. Chemical strip....treat it like an airplane.
aluminum starts to oxidize immediately if not treated. And I can almost guarantee you that you would find a shop that can acid wash and alodine and entire truck."
Haha....whoops - now I see this post. Yes - it's a plane shaped like a truck!
fllaw1
St Augustine, Forida
What paint did you end up using the Satin Rust oleum ? Next do the trailer in black to match.
