Paint question
galeo7171
Cumming, Ga
I'm going to repaint my m1009. I don't have access to an air compressor so I'm thinking about ordering the 383 carc substitute in spray cans from Rapco. Is it possible to make it look half way decent? Will it look a lot worse because I'm using spray cans instead of an air compressor?
319
Lieutenant
58
Michigan
What about an electric sprayer like the Wagner? Anyone use one of those?
I don't think you could get consistant coverage with a spray can.
wsucougarx
65
Washington State
I do not have an air compressor. Could I use the emergency glad hand off the back of my deuce to paint the truck? Is the air pressure high enough? Please advise
ida34
33
Dexter, MI
It is not a question of high enough pressure. Most air paint guns use lower input pressure than the compressor pressure. The big problem is volume. I would say the deuce air system would not provide enough CFM to properly paint with.
wsucougarx
65
Washington State
Re: RE: Paint question
319
Lieutenant
58
Michigan
Even if it did have the pressure and volumne, other issues such as running the truck to keep up the PSI & CFM will cause exhaust particles in the wet paint, and, is the air system completely free of moisture and oil?
Small compressors should not be expensive to rent, just make sure you get one suitable for the gun you're going to use.
AJMBLAZER
Paducah, KY
Do a search. This was discussed fairly recently in the conversations forum and various vendors for it were discussed along with their merits.
