Flyingvan911
- 158
- 63
- Kansas City, MO
I say open all the windows and leave the top on. You get about a much breeze either way but the top will shade you. Drink lots of water!
I have found in my parade experience, 3rd gear low range works about the best. Depends on the pace of the parade, your results may vary.As for the low gear...I was thinking the exact thing, low range on the transfer and maybe 1st or 2nd depending on the pace so as not to have to use the clutch cept to stop. that way I could hopefully just idle along.
.Flags are 3 x 5, conduit is 10' x 1". Photo is from the 2011 Virginia International Tattoo, where I had my truck on display along with a WWI biplane and a English double-decker bus. I'm using wooden flagpoles in this picture.Thanks for the links about the flag. I am now going to go by code and hang it high and proud from the RIGHT FRONT of the truck where it is SUPPOSE to be!!
OldDominionIron: What size are those flags on your truck? I want to get them up and out of the field of view for driving but not have little flags flying that high. I looked at some 3'x5' flags today and they look too small for such a large truck, I like the size of your flags. I'll have to drive down the road the way of the parade and double check some heights cause it is normally NOT a TRUCK route so need to verify the height.
