- 2,054
- 59
- 48
- Milford / Michigan
I looked on all the threads on here and looked in the TM to see how the parking brake cable gets routed. When I bought my deuce, the parking brake cable was routed above the transfer case mount/bar on the driver’s side. this causes a sharp angle right where the sleeve of the parking brake cable mounts on the brake assembly. The TM did not state if it should be above or below the transfer case mount/bar. I looked on other deuces and the few that I looked at were routed ABOVE that transfer case mount/bar. So which is it? It makes sense that it should not have that kind of angle on the cable but the TM does not seem to specify.
