Parking Brake with spring / without?
jatonka
57
Ephratah, New York
The mustache spring keeps the shoes apart so they don't wear on the drum when the brake is off. I have seen them recently with out the holes cast in them for the pins that the spring goes on. They might be aftermarket and the copy cats forgot to copy everything. JT out
gringeltaube
Staff Member
2,300
Montevideo/Uruguay
I think only the very early ones came without the spring and attaching bolts and later this was upgraded.
Agreed that it should have the spring!
So far I have retrofitted two sets with the missing bolts (pre-heat, mig-weld!) and a "custom" do-it-yourself spring. Working well!:wink:
Don't know in your case. I wouldn't bother if I could return those and either get the correct ones or clean your old ones and have them re-lined (1/4"x 3")
G.
