Part from rear brake assembly??
Brodo
Apple Valley, CA
I have always heard a squeak in my RR brake but thought it was cheap pads because everything looked good. I recently heard and felt a grinding noise a couple of times from the rear end (not when braking) so I pulled the rear wheels and drums off and checked the drive shaft ect. It all looked good so I put it back together and drove it again - the squeak was gone and I could not get it to make the grinding noise again. When I pulled back in the driveway I found this on the ground where I had been working. I am going to pull it apart again today but does anyone have an idea of what this is? I suspect it was caught between the brake shoe and dust cover. The head appears to have been square and it is not threaded. 20151223_171203_resized_2.jpg20151223_171153_resized_2.jpg
Warthog
245
OKC, OK
Also in the TM 9-20320-289-20P parts manual. Figure 95, item #5
infidel got me
33
Newberry, Florida
I don't know how brake fluid is not pouring out of your brake drum. If it were me, I would replace both wheel cylinders along with the wheel cylinder link. Don't skip anything on brakes as they are a safety item. Good luck!
