Part number for the long style primary fuel filter
779
20
Springfield AR
OK fellas doing oil change and oil/fuel filters. I need the part numbers for the fuel filters. My primary fuel filter is the long style that is reusable but it needs replaced. I know I can get the others at Napa can I get this one there too. Thanks I couldn't find it the way I was searching.
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
It's a water separator the bottom half is for holding water. The short primary will fit. There are several threads on this. Google search m35 primary fuel filter
Or maybe yours is not military and you need numbers off your filter or housing.
Sent from my SM-G965U using Tapatalk
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I have the long re-usable filter if you "have" to use that style. The short one works just as well imho.
You could always swap to a spin-on while in there. I never liked the primary's placement and that big nut on top the filter, under the alt.
DavidWymore
164
El Centro, CA
Just make sure the center rod/bolt has the cross drilled pin hole and pin/washer to hold the filter at the proper height, up against the head, not sitting down in the bottom. Mine and others were found that way. Whole rigamarole is somewhere in my '62 thread in my sig I believe.
