Part number for the small square vacuum connector on tranny vacuum regulator?
minimalist
texas
I looked through the cucv parts manual with no listing for the square black vacuum connector that connects to the transmission vacuum regulator. The two vacuum hoses then connect into that square block. Is there a part number for this or go ahead and connect the vacuum lines directly to the TVR?
Keith_J
1,316
Schertz TX
Top port on valve goes to transmission. The only reason for the block was to keep he order, as long as you remember the mnemonic of "top to transmission", the block isn't needed.
Warthog
226
OKC, OK
That rubber block is no longer available. Used is the only option.
And yes just remember "top to transmission"
cucvrus
10,045
Jonestown Pennsylvania
Short line goes to transmission. It is the short one that connects to the steel vacuum tube that runs down to the transmission. The other end comes from the vacuum pump located at the rear of the engine.
