Part number for U-Joint in the front axle shaft ???
gjswt19
Texas
I have searched the TM manuals and the only number I could find is the entire axle shaft not just the U-joint. I have searched steel soldiers and can only find the drive shaft u-joints. If anyone knows the part number for the axle shaft u-joint on an LMTV that would be very helpful.
Thank You
simp5782
Feo, Fuerte y Formal
9,366
Mason, TN
DiverDarrell
24
Port orchard, WA
I was thinking the wrong part. Thinking back now, I wish I had taken more pictures when had them out. Any drive line shop should be able to source them.
gjswt19
Texas
I think I have located a part number and will verify once it arrives, CP750N, it says freightliner but is for 2.5 ton Rockwell axles
sjohn116
Baltimore, Maryland
by all means, if I'm wrong, please say so, but I was under the impression that since Spicer invented the u-joint in the early 1900's, any and all U-joints in the market have a spicer series and part number. Easily determined by measuring the cup diameter and the overall width across the + u-joint
The u-joint all by itself should be quickly and easily identified by the technician at any driveline shop.
olly hondro
521
tucson AZ
Slightly off topic: I am looking for two of the long front axle shafts to modify if you guys have any in the parts pile.
You see, when I flip the chunk to a low pinion configuration the long axle becomes too long and the short one too short. If I have two long axles shortened then I could do the chunk flip and axle install the same day.
