part numbers 4 paint
Rustmaster
15701, PA
O.K. i did a search and only really found an on going debate. I have made up my mind to hose my new to me m1009 with sherwin willys 383 substitute. I need the actual part numbers or order numbers for the green and brown. On S.w. web site i just got more confused. Thanks all.
Nonotagain
41
Parkville, MD
Color numbers are:
Green 383, 34094
Black, 37030
Brown 383, 30051
Tan 686A, 33446
The second set of numbers are the Federal Standard 595 color numbers.
If your paint is too glossy, there is a good chance that you are applying it too heavy in one coat.
ida34
32
Dexter, MI
By the way, the Sherman Williams is actual carc and what I gave you is for water cure single component solvent based carc. There is also a two component solvent based carc with different part numbers. The newest stuff is two part water based carc. The industrial coatings catalog has all the part numbers while the link above is only for the single component card.
