Parts for aux fuel system for MEP-016D?
445gsdss
Winchester, VA
Anyone know anyone who sells parts for the MEP-016D - specifically the aux fuel system? My 016 has a belly tank that has hole in in it - right on the molding seam - more like a split. Also, the petcock on the aux fuel system seems frozen. Finally, the water/sediment separator glass globe is missing.
I have reached out to Green Mt - and am waiting for a call back. I'm just wondering if there are any other options.
I'm hoping to find spare parts to get the belly tank running again. Otherwise, the generator drinks down the contents of the small red yanmar tank in about 45-50 minutes - which is a lot of running back and forth to fill during a 24 hour power outage.
Thanks!
-Calvin
Guyfang
26,863
Burgkunstadt, Germany
The metal tanks are the old version. As soon as I can get to me computer, will see if I have info on the pet ok and filter glass and holder. There are at least two different filter housings.
robertsears1
119
Near Apex/NC
Careful use of a torch and sometimes weed eater line can fill a crack or hole in plastic. I assume this was a diesel tank but blowing out the fumes after sitting in the sun all day helps to reduce the chance of a loud surprise.
Robert
dav5
204
Mono, Ontario
Depending on the composition of the plastic you should be able to get it plastic welded. I just got my ATV fender welded for $50.
Guyfang
26,863
If you can get the petcock for that price, grab it. The army paid 43.00 dollars for it.
The filter housing, NSN 2910-00-905-9792, Part number MS51066-1, has 20, (count them, 20 alternate NSN's. If you have no joy in asking the companys I list below, to sell you something, I will post the NSN's
02978L-3 COMMUNICATIONS CORPORATIONDBA COMBAT PROPULSION SYSTEMS 76 GETTY ST MUSKEGONMI49442-1242UNITED STATES
08645BRIGGS AND STRATTON CORP 2711 N 13TH ST 702MILWAUKEEWI53201-0702UNITED STATES
10391CLINTON ENGINES CORP 605 E MAPLE ST 860MAQUOKETAIA52060-0860UNITED STATESFORMERLY CLINTON ENGINES CORPENGINE DIVISION MAQUOKETA IOWA
29510KOMATSU AMERICAN INTL CO 1701 GOLF RD ROLLING MEADOWSIL60008-4227UNITED STATES
29930INTERNATIONAL HARVESTER COAGRICULTURAL EQUIPMENT DIV 401 N MICHIGAN AVE CHICAGOIL60611-4212UNITED STATESFORMERLY INTERNATIONAL HARVESTERCO FARM EQUIPMENT DIV CHICAGO IL
50284CHAMPION LABORATORIES INCDBA CHAMPION 200 S FOURTH ST ALBIONIL62806-1313UNITED STATES
52845KOHLER CO ENGINE PLANT DIV 444 HIGHLAND DR KOHLERWI53044-1500UNITED STATESFORMERLY ENGINE PLANT DIV KOHLER COKOHLER WI
58536FEDERAL COMMERCIAL ITEM DESCRIPTIONPROMULGATED BY GENERAL SERVICESADMINISTRATION WASHINGTON DC
63734KAITLIN CORP 13 POND RD MORSE INDUSTRIAL PK 1540GLOUCESTERMA01931-1540UNITED STATESFORMERLY WARD LAFRANCE PARTS ANDSERVICE INC TAUNTON MA
66289WISCONSIN MOTORS LLC 2020 FLETCHER CREEK DR MEMPHISTN38133UNITED STATESFORMERLY TELEDYNE TOTAL POWERTELEDYNE INC MEMPHIS TN
70040GENERAL MOTORS CORPAC ROCHESTER DIV 4800 S SAGINAW ST 1360FLINTMI48501-1360UNITED STATESFORMERLY GENERAL MOTORS CORP ACSARK PLUG DIV FLINT MI
82386JAIDINGER MFG. CO., INC.DBA JAICO PRODUCTS 1921 W HUBBARD ST CHICAGOIL60622-6283UNITED STATES
92679NAVISTAR INTL CORPMELROSE PARK ENGINE PLANT LOCATION/MELROSE PARK/ 10400 W NORTH AVE MELROSE PARKIL60160-1065UNITED STATESFORMERLY INTERNATIONAL HARVESTER COMELROSE PARK PLANT MELROSE PARK IL
92878HDT EXPEDITIONARY SYSTEMS, INC. 30500 AURORA RD STE 100 SOLONOH44139-2776UNITED STATES
96046CRANE PUMPS & SYSTEMS, INC. 420 3RD ST PIQUAOH45356-3918UNITED STATES
96152BORG-WARNER CORPMARVEL-SCHEBLER/TILLOTSON DIV DECATURIL62521UNITED STATESFORMERLY MARVEL-SCHEBLER/TILLOTSONDIV BORG-WARNER CORP DECATUR IL
The above list is of company's that supplied the filter housing to the Army. One of them has got to sell to you.
MOUNTING TYPEINLET CONNECTION HEAD SIDE AND OUTLET CONNECTION HEAD SIDE
BODY LENGTH3.250 INCHES NOMINAL
BODY WIDTH2.750 INCHES NOMINAL
BODY HEIGHT3.875 INCHES MAXIMUM
WIRE DIAMETER0.0045 INCHES NOMINAL
MESH SIZE100.0
FEATURES PROVIDEDDRAIN PLUG AND MANUAL SHUT-OFF VALVE
FILTERING MEDIA DESIGNMESH SINGLE FILTERING MEDIA RESPONSE
FIRST INTAKE CONNECTION TYPETHREADED INTERNAL PIPE HEAD SIDE
FIRST DISCHARGE CONNECTION RELATIONSHIP TO INTAKE CONNECTIONIDENTICAL TO FIRST INTAKE CONNECTION
FIRST INTAKE THREAD SERIES DESIGNATORNPTF
FIRST INTAKE NOMINAL THREAD SIZE0.125 INCHES
FIRST INTAKE THREAD DIRECTIONRIGHT-HAND
SPECIAL FEATURESGRUMMAN AEROSPACE CORP A10 AIRCRAFT
MATERIALCOPPER ALLOY SCREENING
MATERIALCOPPER ALLOY SEDIMENT BOWL
MEDIA FOR WHICH DESIGNEDFUEL/OIL, HYDROCARBON
III STYLE DESIGNATORUNTHREADED SHELL W/SELECTIVE FLOW
The above list is tech data for the filter housing.
strycnine
Claxton, GA
02978L-3 COMMUNICATIONS CORPORATIONDBA COMBAT PROPULSION SYSTEMS76 GETTY STMUSKEGONMI49442-1242UNITED STATES
08645BRIGGS AND STRATTON CORP2711 N 13TH ST702MILWAUKEEWI53201-0702UNITED STATES
10391CLINTON ENGINES CORP605 E MAPLE ST860MAQUOKETAIA52060-0860UNITED STATESFORMERLY CLINTON ENGINES CORPENGINE DIVISION MAQUOKETA IOWA
29510KOMATSU AMERICAN INTL CO1701 GOLF RDROLLING MEADOWSIL60008-4227UNITED STATES
29930INTERNATIONAL HARVESTER COAGRICULTURAL EQUIPMENT DIV401 N MICHIGAN AVECHICAGOIL60611-4212UNITED STATESFORMERLY INTERNATIONAL HARVESTERCO FARM EQUIPMENT DIV CHICAGO IL
50284CHAMPION LABORATORIES INCDBA CHAMPION200 S FOURTH STALBIONIL62806-1313UNITED STATES
52845KOHLER CO ENGINE PLANT DIV444 HIGHLAND DRKOHLERWI53044-1500UNITED STATESFORMERLY ENGINE PLANT DIV KOHLER COKOHLER WI
63734KAITLIN CORP13 POND RD MORSE INDUSTRIAL PK1540GLOUCESTERMA01931-1540UNITED STATESFORMERLY WARD LAFRANCE PARTS ANDSERVICE INC TAUNTON MA
66289WISCONSIN MOTORS LLC2020 FLETCHER CREEK DRMEMPHISTN38133UNITED STATESFORMERLY TELEDYNE TOTAL POWERTELEDYNE INC MEMPHIS TN
70040GENERAL MOTORS CORPAC ROCHESTER DIV4800 S SAGINAW ST1360FLINTMI48501-1360UNITED STATESFORMERLY GENERAL MOTORS CORP ACSARK PLUG DIV FLINT MI
82386JAIDINGER MFG. CO., INC.DBA JAICO PRODUCTS1921 W HUBBARD STCHICAGOIL60622-6283UNITED STATES
92679NAVISTAR INTL CORPMELROSE PARK ENGINE PLANT LOCATION/MELROSE PARK/10400 W NORTH AVEMELROSE PARKIL60160-1065UNITED STATESFORMERLY INTERNATIONAL HARVESTER COMELROSE PARK PLANT MELROSE PARK IL
92878HDT EXPEDITIONARY SYSTEMS, INC.30500 AURORA RD STE 100SOLONOH44139-2776UNITED STATES
96046CRANE PUMPS & SYSTEMS, INC.420 3RD STPIQUAOH45356-3918UNITED STATES
96152BORG-WARNER CORPMARVEL-SCHEBLER/TILLOTSON DIVDECATURIL62521UNITED STATESFORMERLY MARVEL-SCHEBLER/TILLOTSONDIV BORG-WARNER CORP DECATUR IL
MESH SIZE100.0
Wow!:-o
