Parts from Mil Spec numbers
cobratodd
Connecticut
Is there a site that sells parts based on Military Part numbers? Or a conversion to common part ID such as threads per inch, pitch, material, elbow, etc?
I'm trying to find a replacement fitting for a leaky air line to the poppet valves on the transmission on my M813. The part number is (From the TM):
PAOZZ 81343 6-4 120202BA(LON ELBOW,PIPE TO TUBE 2
It's a 90* elbow with a compression fitting on one end and threads on the other end.
Also looking for the copper tubing, not sure if there's anything special with it.
Thank you,
Todd
jasonjc
291
Gravette Ar.
You can go to this site WebFLIS - Public Search It will give you some info on the part. It will also show other part numbers for the part if there are any. You have to rember that the gov buys from the lowwest bidder, they (bidders) all use there own part numbers for stuff. 1 part may have 10 or 20 different part numbers.
SCSG-G4
PSVB 3003
5,388
3,442
Lexington, South Carolina
the first part is the codes for the replacement availability, the second part (81343) is probably the CAGE code of the original manufacturer, the rest is the part number and description.
You can also use the ALI Partsmaster site if you have the NSN or just the part number >
PartsMaster Menu
cobratodd
Connecticut
Wholly - Molly!!!!! Went on line to one of those "part number get your quotes here" places, entered the gov spec part number and received a quote:
Hi Todd,
In response to your request we are pleased to quote you the following:
PART#:
6-4 120202 BA
NSN#:
4730-01-420-8036
DESCRIPTION:
ELBOW,PIPE TO TUBE
CONDITION:
NEW SURPLUS
QUANTITY:
TRACE:
LEAD TIME:
IN STOCK
PRICE:
$ 98. ea
Please feel free to contact me with any questions.
Granted, this is a 90* elbow for 3/8" copper line with threads on one end and a compression fitting on the other end - $98.00 each!!! hahahahahahahahahahahahahahahah -
Looks like I'm taking the part to the plumbing supply house to have it matched up.
doghead
4 Star General /Moderator
1,184
NY
