Parts truck
m-35tom
229
eldersburg maryland
kenny, memphis had some. i have 2 for the 17' 5 ton. the harness ending in 6001 does have a starter switch connector (74) but uses a generator (easy to convert) and does have turn sig but not the harness going up the column as it used the old relay box type, but the numbers are the same and you can get the column harness for most m series and splice it or put connectors on it. so..... new harness, mostly correct and cheap. lots available (600) at saturn.
sermis
17
Temple, TX
Well I got the truck to run. Rigged the plastic fuel lines up. Nobody had the male
compression fittings so I used a male splice and made it work. 5 gallon can with fuel line to the primary fuel filter. A shot of starting fluid and it busted right off but died. Another shot of starting fluid and it was running. Total pull was about 30’. No alternator so the water pump was not turning. The return fuel line was running out on the ground. Drove the truck about 400’ and parked it. There is some type of problem with the motor or transmission. Not sure if it is a knock in the motor or bearing in the trans. It has a “C” turbo and spools up and down and can be heard over the motor noise.
