Passenger Seat Back Removal
rboltz
Hershey, PA
Does the passenger seat back assembly "hook" at the top and fasten with two bolts at the bottom? I need to remove it from the cab for the media blasting and can't see back there.
1943ht
94
Clermont Florida 34711
That's affirmative .. two 5/16 NF (24) bolts on the bottom ... just did my seat back yesterday regards those bolts .. ran a tap thru the holes to clean them up :wink: before installing.
rboltz
Hershey, PA
Thanks again to all. I still hope to have everything blasted and painted by summers end. Then, rewire and reassemble over the winter. My only dilema is the tail gate. It's bent several ways and I have no way to straighten it.
majorhitt
Dallas Pa.
Lost my brackets, fabbing new ones. Then when just about to install the new brackets and the originals showed up!! Yes just like everyone said two bolts on the bottom and drop in on the top.
M-37Bruce
59
Midlothian, VA
I'll make an effort to get out in this heat and take a pic of mine, I will need to remove said cushion. I have one original and one house/home made.
majorhitt
Dallas Pa.
I had the seats out of my M37cdn. You could see the 1/4' bar that goes from bracket to bracket on the top, the two humps are where the support brackets go. Then on the back of the cab I held a pointer at the bracket. I should have moved to the right to get both brackets in the picture. Hope this helps.
1943ht
94
"T-H" where are you located in WI? I'm in River Falls WI (MN Border)and am just finishing up my M37 Restoration .. My thread on the M37 Forum is "Another one Bites The Dust."
//R//
Mark
M-37Bruce
59
Midlothian, VA
This looks tighter than the one I have, I guess the tighter, the closer to the back? If you making a few, I would like to purchase one if it's possible?
