Passenger Seat Connecting Link Incorrect?
Gypsyman
740
Quincy, FL
I've started working on my seats and run across something odd. The connecting link on the outside of the passenger bench appears to be too long. When I purchased the truck I noticed that the link was bend outward. Simple fix so I never paid any attention to it. The more I looked at it though the more it appeared to be the wrong length.
When the seat is in the upright position the link is far from being out of travel which allows the seat back to rest (and rattle) against the back of the cab. When the seat is folded down it's about 3/8" too long so if you put weight on the back of the seat the link bends outward. The geometry or length appears to be all wrong.
1) Have others seen this issue?
2) Is this a common problem?
3) Can someone verify the overall length of the link?
I've only been able to find one sample photo and I can see that the link is at the end of the slot when the seat is in the upright position. This appears to be correct.
Gypsyman
740
Quincy, FL
When you have time could you tell me the overall length of the link? I can't find any local trucks to look at. Mine is right at 14-7/8" overall.
The part numbers show none available at the usual sources.
  • Like
Reactions: HDN
Gypsyman
740
Quincy, FL
Something is definitely goofy with mine then. It's 3/8" too long in the down position and around 1" too long in the upright position. Maybe the tab on the seat back was welded in the wrong position or this seat was pieced together from two or more.
Worst case scenario I guess it's cut and weld time.
Does the lower bolt rest against the end of the slot in the down position or does the seat just ride cushion to cushion? I know that the driver side arm seems to stop the seat back in a level position when folded so it appears to be correct.
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
Does the lower bolt rest against the end of the slot in the down position...?
Yes.
And it should not be this link that limits the travel to the fully up-position. There are stop brackets welded for that purpose, on both sides of the seat.
I guess what really matters is the C-C distance between bolts: measured 9.5" and 13.4", respectively.
Gypsyman
740
Quincy, FL
I saw that the seat has built in stops but mine is still resting against the corner brace in the cab. I had planned to add a small amount of material to the stop area to kick the back forward just a bit. Apparently it's been hitting for some time as there is a small divot worn in the seat back.
I'll check dimensions in the morning. As always, thank you for the precise answer.
On a side note...
30 days out on hood handles thanks to you. =)
Gypsyman
740
Quincy, FL
After some additional measuring I settled on dropping 3/8" in length from the middle of the link. Pictures below are after the cut/weld/paint modification. Everything works perfectly. I have no idea where the variance was but both forward stops hit at exactly the same time now and the back sits level when folded down.
One more small item off the list...
