PE-95 generator
gstirling
20
knoxville tn
I'm restoring a PE-95 generator and have found two manuals, 919-TM11-904 (kind of an overview manual) and TM-9-1804A (covers the engine only). what i'm hunting are the repair manuals that list each part and the parts breakdown. For my 936 i have operations manuals and parts manuals... was hoping to find the equivalent parts manuals for these generators. general searches in SS and out on the internet have not turned anything up? does anyone know if they exist or better yet, have copies???
rickf
2,254
Pemberton, N.J.
Google search for "Military PE-95 generator manuals" and I got a lot of hits for manuals. I am not familiar with the WWII sets so I don't know what I am looking at.
NDT
7,534
Camp Wood/LC, TX
What suffix letter do you have on the PE-95? There are -A to at least -E. They are different internal configurations.
gstirling
20
knoxville tn
gstirling
20
knoxville tn
I'm not sure what i'm looking for either (number or title wise) my searches all turn up the same two manuals i have 904 and 1804 depending on search criteria i used - like - jeep willy engine, or PE-95, or WWII generator, military 10kw generator. was just hoping maybe someone who worked on these in Korea or maybe as late as Vietnam (might have still been using them) would know if the Army even put out other manuals. or what i have is what there is...LOL
gstirling
20
knoxville tn
These are all I can find. go to the TM 9-904 and look at appendix A for mention of other references.
thanks for looking, those are the ones i have or a close variant. its beginning to look like that's all the Army published for them. no detailed parts manual or higher level maintenance manuals.
gstirling
20
knoxville tn
the engine side of the rebuild is covered, both civilian jeep manuals and army manuals. but the generator itself, that is what i think i'm missing. there must be some guidance the army had on how to align the generator shaft with the engine. mine had 3 shims that fell out when i was disassembling it (there are 4 bolts that hold the rotor to the flywheel) , and i did not notice them till much later, so not sure where each one went. they appear to be .001 in. thick or so. i can find imprints on the flywheel to locate two, but not sure about the third and which bolt had none. the design of the unit is such that these are not reachable once the unit is assembled. so my fear is ensuring the alignment prior to running it on the engine at speed. no way i see to ensure the stator and rotor are not rubbing. thanks all for the input.
