Peel and Seal Type Flashing for Sound Deadening
01GRANDER
56
Alabama
I know my Alabama side is showing on this thread but has anyone used Peel and Seal flashing or the equivalent for sound deadening on the underside of the HMMWV body?
I have actually used it instead of Dynamat and it seemed to work well. The alternative is a spray like Lizard Skin and that has a tendency to chip or flake off. I would think it would work well, I have no idea how well it would hold up though.
TOBASH
3,946
Brooklyn, NY
What a great idea. About as great as adding a thousand dollar PCB/EESS to an otherwise simple glow plug setup.
Now you just need that "Cable Guy" and you can start a road show.
01GRANDER
56
Alabama
People use it for speaker setups all the time and it works well. My point is that the “professional” spray seems to be very thin, expensive and I have seen it chip. Not saying it’s the best idea but it’s probably not the worst.
DREDnot
587
Phoenix, AZ
I doubt it will last long on the underside of the body. Ive used that cheap stuff from home deeps on my M1009 under new rubber flooring/padding and it made a difference.
I would suggest putting it on the inside covering the hottest and most resonant areas of the floor and tunnel and then top with the original military foam insulating pads
TOBASH
3,946
Brooklyn, NY
The interior of your HMMWV looks remarkably similar to an old Chevy Suburban. 🤪
Interesting use of that stuff BUT I’m considering Dragon Skin [EDIT - I meant Lizard Skin] for sound and heat. Dragon Skin [Lizard Skin] is not very expensive, it is water soluble, and it is easy to spray. Then I will cover it with the rubber mat and see where I stand I guess.
Best,
T
Aguanga, CA
Interesting use of that stuff BUT I’m considering Dragon Skin for sound and heat. Dragon Skin is not very expensive, it is water soluble, and it is easy to spray. Then I will cover it with the rubber mat and see where I stand I guess.
Best,
T
I'm curious about this Dragon Skin stuff and how it compares with the Lizard Skin.
