Pick-up/speed sensor MEP-805B
Dieseljo
10
Nederland
Hello everyone,
Oure MEP-805B has a broken pick-up sensor. I can’t find any on the internet. And want to replace it for a retail. Does anyone know. Where i could find this. Or perhaps knows the resistance of this sensor. You would be of great help. Because where running this generator off grid. Thanks for reading.
Hope you can help me out.
Light in the Dark
5,922
MA
Have you looked through the -24P manual for this particular machine, to ascertain either an NSN or a manufacturer number? Would help your search greatly.
Light in the Dark
5,922
MA
If you are unfamiliar with how the TMs work on these sets, see the info below for your machine:
#2 call out for the MPU
Few pages later in the same book:
Part number on the item you need is MSP675C... which should tie back to Governors America: https://www.governors-america.com/products/msp675
Seems there are other items available generically for the same thing, but that should have been the OEM unit in there.
Dieseljo
10
Nederland
Thanks for you’re fast reply. You definitely helped out on this one. I couldn’t find this in the manuel i have. Some page’s seems restricted. Possible because my IP aint form the U.S? Or just the wrong manuel
Light in the Dark
5,922
MA
I would redownload all of the manuals for your machine here: https://www.steelsoldiers.com/threa...to-work-on-the-mep-805b-generator-set.173097/
Each one does different things... lubrication order, operating manual, technical troubleshooting, exploded parts diagrams, etc. Having all of them will give you a much more complete understanding of the machine, as they feature distinctly different information. Good luck getting it operational.
Dieseljo
10
Nederland
Thank you very much. Im sure we will get it running now
Dieseljo
10
Nederland
If you need help to understand how to read the TM's, say something. What TM are you using? Did you down load it from the TM forum here in Steel Soldiers?
I will make a screenshot. Somehow even from links i have got from you guys. Simply dont open…
