Picked up 804a and 802a today and looking for advise.
Mattguy
1,332
Highland, Indiana
Picked up two units in Capac, MI. The 804a is a runner the 802a was sold as not running. After getting the 802a home and taking a closer look, its missing the fuel stop solenoid and I'm trying to figure out what else is missing in the picture. At $627 out the door with fees, is it worth it to try and put the missing pieces back together and see what happens?
Farmitall
276
Eubank, KY
I'd say it would be well worth fixing up the 802a as long as there's not internal damage. Does the crank rotate?
If it were mine, I'd inspect it closely externally, list the missing parts, then buy a complete gasket set and then go internal.
You could also part it out and more than recoup your costs.
Mattguy
1,332
Highland, Indiana
In addtition to the solenoid it's also missing:
Radiator hoses
Primary fuel pump and possible some fuel line
Fuel return line
Fuel filter
All easy fixes
Open the gauge panel and take a pic in there
Thank you I'll get picture today of panel. I already ordered the hoses from Light in the dark. All the filters are sitting here. I was looking at green mountain parts and the solenoid was over 200!
Light in the Dark
5,830
MA
And there is a mounting plate missing for the FSS. I have one. Also you will need the hardware set that goes with the FSS as well. Onan asks $110 just for the armature that comes out of the FSS. I have used sets available (and the mounting plate too).
Edit: Your mounting bracket is there, I just missed it (behind the OD strip, with the chain).
Ray70
5,788
West greenwich/RI
Like Farmitall said, do a complete inspection of the engine before you buy anything. Often times there's a good reason why so many parts have been "Borrowed" from it. Either way, anything can be fixed but a seized engine can throw a curve into your plans.
Then just do the bare minimum to get it to start.
No need for the hoses or throttle solenoid at first, just get the fuel system fixed up and the oil system put back together.
disconnect the VR for now and crank it from the dead crank, if no banging noises come from inside, fire it up and see where you're at.
If it runs, then continue on with the repairs.
The beauty of a diesel is that all you really need is a starter and a fuel supply to make it run....
Mattguy
1,332
Highland, Indiana
She turns over. With the starter and by hand. So no frozen engine, thankfully.
loosegravel
Just a retired mechanic who's having fun!
504
890
Enumclaw, Washington
I also buy these units from auction, sight unseen. It’s a gamble, a crap shoot…however you want to say it. Most of the units that I bid on are a few hundred miles away. When and if I win them I’ll go and haul them home with my flatbed trailer, or if they’re trailer mounted I just tow them home. I’ve only really been burned once when I picked up a 803A that was missing the rain cap. It’s always fun to bring these units home, get some coffee and go up to the shop and spend some time on them. I rarely have to spend much time to bring them back on-line. I also had another 803A unit earlier this year that needed some internal engine work. The design on the Lister/Petter engines with the trap door on the side of the block allows you to remove pistons/rods etc without pulling the engine. As Kurt mentioned, inside of the control panel is a series of relays and one “frequency trip switch” that looks similar to the other relays, but is different. Check to see if there’s anything missing and/or in the wrong place. I’ve had a couple of units that were missing one or more of them. Also, one other unit that had the frequency trip switch in the wrong place. I let the smoke out of it when I brought 24vdc up to the panel😣 The help and guidance from this forum is excellent. Good luck with you!
Mattguy
1,332
Highland, Indiana
I also buy these units from auction, sight unseen. It’s a gamble, a crap shoot…however you want to say it. Most of the units that I bid on are a few hundred miles away. When and if I win them I’ll go and haul them home with my flatbed trailer, or if they’re trailer mounted I just tow them home. I’ve only really been burned once when I picked up a 803A that was missing the rain cap. It’s always fun to bring these units home, get some coffee and go up to the shop and spend some time on them. I rarely have to spend much time to bring them back on-line. I also had another 803A unit earlier this year that needed some internal engine work. The design on the Lister/Petter engines with the trap door on the side of the block allows you to remove pistons/rods etc without pulling the engine. As Kurt mentioned, inside of the control panel is a series of relays and one “frequency trip switch” that looks similar to the other relays, but is different. Check to see if there’s anything missing and/or in the wrong place. I’ve had a couple of units that were missing one or more of them. Also, one other unit that had the frequency trip switch in the wrong place. I let the smoke out of it when I brought 24vdc up to the panel The help and guidance from this forum is excellent. Good luck with you!
Thank you! And I thought I was dragging mine home too low. . I plan on buying a few more of these but no trailers, much easier to bring my own. I will tell you that it pulled like a dream 290 miles!
loosegravel
504
890
I always tip the guys in the yards who load me up. I’ve been able to get to know a few of them along the way. These are the same guys that take the photos, and check them out. They all tell me that they don’t spend a lot of time to get them running. They’ll fill the crankcase with oil, they’ll plumb some fuel to them and they’ll jump them with 24vdv to crank them up. If they don’t fire off, they list them as “not running.” If they’re missing any components like your (802A was) then they won’t spend any time on them, list them as “not running.”
loosegravel
504
890
And, of course they don’t load test them. You may see a short video with a drill motor or something like that plugged into the convenience receptacle .
Mattguy
1,332
Highland, Indiana
I know the guys from Wisconsin and Michigan. Always nice! Helped me fill up air on tires, even offered to lend me a hitch when mine was too low. Never had an issue with govplanet except for the sf97's. But that's a whole different story. He did tell me they just have a shop light they plug in to test for power at recepticals.
19,721
Just a pure speculation swag but Ukraine is in need of gen sets and I suspect working units will be diverted instead of surplused to dla. Ymmv
I dunno...
I can't quite see our military or government in general spending the thought it would take to send a used machine to Ukraine. They would rather spend the money for a new (insert NSN here) rather than test and confirm a running model. Different bucket of money...
