ODdave
- 38
- 0
- lansing michigan
So i picked up a MEP-017A last night, after skimming through the manual and tinkering with it i got it to fire up. It ran fine for the first few run cycles but the i lost spark. After removing the mag and cleaning the little bit of rust from it, it runs great!
My questions are,
Where can i get the correct battery for it? or is there a easy/ clean alternative?
If i let it run at an idle for an extended amount of time will it hurt anything? how long can/ should it idle?
What is the magneto point gap to be set at?
Where can i find a new air intake tube? the rubber one from the air cleaner to the carb.
My questions are,
