Picked up The MEP-002 last weekend
simpleserf
Sherman, NY
Just figured I would say hello, though i have been a lurker here for some time. I just picked up an MEP-002 this past weekend, and am looking forward to putting it to work. The unit is on a M116A2 trailer and should make a good backup unit for the house as well as a good portable/3phase source for my shop. I was going to go with a J series Onan, but after seeing the how these are built, I'm hooked.
Paul
Triple Jim
277
North Carolina
That's pretty much where I am too, Paul. My "new" MEP is a pleasure to run, compared to what I've had to use before. My neighbors should be glad I got it too, because it'll be years before we have an outage, now that I'm prepared.
epitts
Terre Haute, Indiana
We have had two outages since I got my MEP-002 a few months ago. Now I have the plugs and wire to hook it up to the house. Pin and sleeve conectors cost mucho bucks.
Triple Jim
277
North Carolina
I think I'd spend the money on a transfer switch and hardwire the generator to it, before I'd spend the money for the pin and sleeve setup. It's easy enough to take the wires loose at the generator end if needed. No question that those connectors are first-class though.
simpleserf
Sherman, NY
Yeah, Pin and sleeve can be expensive, though I have a set that was scrapped from work sitting around somewhere...
We bought this house a year ago, and It has a ITE pushmatic box that has many many issues. I am having it changed out this fall, and when I do, a 200A transfer switch is going in.
Triple Jim
277
North Carolina
It's always good when you can get the stuff that's thrown away. I used to work at a place that had a great dumpster. I'd dive right in.
DeucesWild11
12
Putnam County, NY
I think I am going to get one at some point as well for backup to my house. I see the two common models are the 002 & 003. I know the 003 puts out a little more power but is it worth the extra $$? How much extra would you pay between models? I have seen around $500 difference.
Thanks!
Triple Jim
277
North Carolina
The MEP-003A is rated conservatively at 10 kW, twice that of the MEP-002A. Fuel consumption is also double. I got an MEP-003A because I wanted to be able to run the whole house without load shedding, and we don't have outages very often, so fuel consumption isn't a big factor.
