Wouldn't larger diameter tires be better in the snow? Not as much wheel speed, causing less of a chance to spin on you. I could be wrong, but it sounds logical to me. I would run the 16.00's aired down giving you more contact surface. Either way, these trucks aren't the greatest in snow from what I have heard. I have not had a chance to get mine out in the snow yet.I really like the look of the 395 goodyears on there also look wider than they really are when compared to the michelins of same size or any of the 14.00-16.00's.
one question for you guys running the Hemtt rims, with the combat rims I know the front and rear tires track close to same width on the hemtt's wouldnt the fronts stick out further and rears set in further making it a bigger difference in tracks? How bad is the difference? looking down side of truck does the rears looked "tucked in" further than they actually are?
I'm asking because I am looking for an a2 truck (which comes with the singles already) but I also have 395's and hemtt rims already, I was going to put MVT 395s on hemtt rims for winter use (shorter tire= lower speed for bad weather and they have more biting edges) and then run XZL 16.00's through summer on the stock 5 ton combats. I also thought of buying standard 923 and using the hemtt wheels to single it out. I just really dislike the rear of a truck being narrower than front and on most my 4x4 I use different back spacing on rear or run spacers to even it up.
I have a pic of 395 michelin xml beside a MVT for comparison (not really sitting level though so goodyear looks shorter but trust me they aren't)
When I buy mine I'm going with the 16s. I think the benefits outweigh the negatives. They fill the fenders out better, taller sidewall clearance, better flotation, more diff clearance, more tire flex and better road gearing. Just a better choice for offroad. To get more power you could find a 350 ntc small cam and stuff it in there.Check out my avater, I have a M925A1 with the stock super singles. But im starting to wounder if maybe the 16's would be better? I guess its all personal preference.
You keep mentioning speed, but neglecting the fact that the 14.00's and 16.00's are only rated 55 MPH top speed! Where as the Goodyear G177 11.00 are rated 65 MPH top speed! So you can go almost 60 MPH with the 11.00's at about 2200 RPM. But you safe top speed with the bigger tires is only 55 MPH. So the 11.00 are better if you want to drive over 55 MPH safely.I have had stock 1100's, 1400's and 1600's on my truck. 1100 are stable, cheap and slow! 1400 are smooth riding, harder to find in good condition and give a good highway speed. 1600's look cool, can be found at fair prices, but ride like crap and suck the power. You can get more highway speed out of 1600's but it is not a fun ride, now with 1400's you can't go as fast but the ride is a lot nicer.
Oh and if you haven't guessed yet. Yes 1600 will fit on a M923, but there is only 3/4 inch between the rear tires and the fronts will rub on the pitman arm and hydraulic assist cylinder in the front.
That is how my truck is. It has 14:00s on it now, but 16:00s are coming soon.I know this thread has been dormant for a while but if you're having bed clearance issues on 16.00s. Why not just replace the boards under the bed with taller boards and have some longer u-bolts made up to remount the bed a few inches higher.
What exactly are the tires pictured? What are the dimensions?16:00s's fit fine. They do sap some power , but its not that bad. Goodyear 16:00's look smaller than the Michelins. I believe the michelins are a better tire.
One thing to consider is the speed rating of the tires. The Goodyear 395's are rated for 68 mph the others at 55. If you plan on driving at speeds over 55 and you have a wreak, you can bet the LEO's and lawyers will be looking at "possible" reasons for fines or lawsuits. Let's not give the public or law makers more reason for more restrictions to our OD addictions. Just an old OTR retired driver thinking out loud. Peace out.
The only gain from the larger tires is lower RPM at top safe speed. NOT faster!
Someone posted a letter from one of the tire manufacturers (think it was Michelin) stating that the max speed ratings were at full-load, and articulated that it's okay to run over max speed when unloaded.16.00's are rated 55mph at full rated load. 14000+ lbs per tire, on a m923/925 you've got less than 3700 lbs on each tire (average). Ive driven my M932 over an hour at 65-75 with NO shaking or wobbling and my michelin XZL 16.00's were barely warm to the touch.
