Pictures of how a Gauge Cluster wiring is supposed to look.
F0Rabbit
WV
Looking for how the gauges are supposed to go in, My 1010 came with Spaghetti behind the dash and aftermarket gauges. Hoping I can just get a used stock cluster and put it in. If anyone has pictures or diagrams of it thatd be great.
F0Rabbit
WV
Thanks. As Im reading more and more I feel like Im in over my head. The previous owner had removed the wires for the gen 1 and 2 lights. Is that part of a 24v to 12v convo? Also Im missing allot of the parts the dash lights go in. Where could I find those? Lastly, one of the turn signal "wiring" on the circuit is completly gone. How do you repair the wire and plastic?
cucvrus
10,225
Jonestown Pennsylvania
You need a new printed circuit board. And it does appear to be altered and that will be hard to repair. It looks like it may be easier to replace the entire harness.
joshuak
214
Slower shore, DE
It's only difficult if you don't know how. May I suggest that you take your time, read and ask questions as needed.
I may be mistaken, but I don't think the Gen 1 and 2 lights work in the M1010 in the OEM configuration.
Post a wanted add when you're sure of the pieces you need or would like to add.
Lastly, one of the turn signal "wiring" on the circuit is completely gone. How do you repair the wire and plastic?
Check the helpful threads, folks have repaired their circuit boards and posted how they do it.
About the missing wires on the plug, don't stress, my m1010 harness is the same. Pic. bellow.
