Pimary Filter Housing Removal
Varyag
Garfield, Washington
I am having a **** of a time removing the housing from the primary fuel filter. I have read up on it and I can't find anywhere you can get a 1 inch wrench on. I have tried spinning the whole body off and broke my filter wrench trying. Is there something I am missing? I can see where it would screw out but I am just failing completely on removal. I know I am going to more then likely destroy the O-ring pulling it apart and am more then willing to get a replacement.
1,172
There is a bolt head on top of the filter housing, under the alternator.(on top) You do not spin the housing.
This is where looking at the -20P TM is useful. It gives you an exploded view of the item. That makes disassembly, self explanatory.
item 7 is the nut you need to loosen.
mcmullag
13
Colorado Springs, CO region
Just changed mine recently, the nut you have to turn is in the area under the alternator. It is hard to get to and only room enough to make short turns with the wrench. I had to keep flipping the open-end wrench over for the different angle of approach with the wrench. It is a pain.
91W350
57
Salina, Kansas
Might unhook a battery cable and save the possibility of grounding the wrench to the alternator. I have not personally experienced it, but have read that it can be expensive. Glen
Jimma
Hartwell, GA
I had to loosen the bolts that secure the alternator, push it over and then had good access to the bolt. It makes the job easier if you have one person under the truck supporting the canister as you loosen it. Not only does that keep it from falling and hitting the ground, spilling everywhere but they can take the weight off of it as it loosens making your job on top easier.
1,125
Is it a 1" bolt? I could have sworn they were 3/4".
289
Hampton, Virginia
It takes a 1" wrench to remove the primary fuel filter. I had a hard time removing one once then took a good second look and found the wrench was binding up on me. I repositioned the wrench and the nut came loose pretty easily.
BadMastard
Duvall, Wa.
Must be the day for fuel filters. I just took mine off and replaced it with a spin on from Napa. My drain wasn't working on the stock one. I actually took off the fuel lines and removed the filter with the bracket on it. That's when I discovered it had been vice gripped on the fuel lines, and the brass fittings weren't fitting anymore. A quick trip to lowes and Napa, and a bit of welding and it's now a spin on filter. Of course, the new filter? The drain valve is broken.
