topo
- 277
- 63
- farmington NM
I would like to see a better park brake on these trucks at least one that can be trusted to hold a loaded truck on a hill .
We performed those 20 MPH tests all the time on the buses. In fact it is mandatory before and after a brake job. You do the test three times, and it must fall within specs every time. The parking brake test is performed every 6,000 miles.Though is was at five mph the truck should stop in 20 feet with just the emergency brake pulled and truck aired up. I would be willing to bet if I was pull just my parking brake on my 915 she will lock up at higher speeds just going to be a long stopping distance. Would hate to try it though. The S cam on my trailer will lock them up to if the trailer becomes disconnect. With air brakes the adjustment is the important thing. Even automatic slack adjusters can fail to adjust. As said I would forget the pinion brake. With the Deuce yes I would pull the engine shut down if a emergency came up. The best thing for a system like the Deuce or 809 series is to KNOW the slave cylinders are in good working order. From there then is a good working master and air pack.
Here are the guide lines for 20mph. The figures would then go up as the speed increase. I guess they figure if your air brake system can be within the guidelines for 20mph then it should stop at higher speeds just need more footage. The problem would be the DOT officer could not make use do a 70 mph emergency stop as things could go very wrong. So they just could have us do one at 5 mph. Never seen a Dot officer test the brakes that way they just measure the throw.https://www.law.cornell.edu/cfr/text/49/393.52
Actually, had you searched before asking, before buying, you would have a full bank account still.I posted to get peoples opinion on the subject, I got a lot of different ideas but nobody seems to know for sure.If you don't want discussion then don't reply!
I for one will be glad to see some real world info from them. Please post your results once you get them on and try them out, good bad or indifferent.Sandcobra,you sound like a very intelligent person but you missed the point,I'm not replacing the E brake I'm adding 2 pinion brakes and leaving the stock brakes.It has nothing to do with monster trucks.I don't care how much it costs or how long they last ,it's just a toy.I'm sorry I posted on this forum because it ruffled the feathers of the gurus.I was trying to get imput and have a discussion, but apparently that is for a different forum!
Apparently you should have done your homework before buying the parts if you wanted advice. By asking for "how good will a pinion brake be?" After you already bought them means you have already made your mind up to install it. You should have upgraded your existing brake system if you were looking for better braking and safety over what "looks cool" when 1 in 5 people who will look at your truck will even have a clue as to what it is. Pinion brakes should only be used offroad applications or for a parking brake in my opinon. But in your case your decision to install a pinion brake may be your only savior.Sandcobra,you sound like a very intelligent person but you missed the point,I'm not replacing the E brake I'm adding 2 pinion brakes and leaving the stock brakes.It has nothing to do with monster trucks.I don't care how much it costs or how long they last ,it's just a toy.I'm sorry I posted on this forum because it ruffled the feathers of the gurus.I was trying to get imput and have a discussion, but apparently that is for a different forum!
With all bashing, Its still not clear how your going to use these, are you plumbing them into your primary brakes, or are they going to be used as an emergency brake system only.Thank you all for your input.I will be running 2 pinion brakes 4 drum brakes 1 emergency brake with a Rockwell locker in the rear and a ARB in the front,sometime this year I will put disk brakes on,but that looks like a lot of work.I am 70 years old and always done things against the grain,please don't take this personal but I'm going to try this and I will report the results.
So what are you going to use for a proportioning valve ?For now I'm going to plumb it into the stock system,but a dual system sounds pretty good.
Well your at that bridge as soon as you hook into the stock system , they will lock as soon as you apply the brakes and you will never get enough fluid to the wheel cylinders to activate the wheel brakes without a proportioning valve matched to the spring tension on the wheel brakes . This is hydraulic braking 101.I don't know,I'll cross that bridge when I get to it.
Might I suggest searching brake failures here? It's unfortunately common with the single circuit system. Maybe it will convince you to at least use a dual circuit system. I'm guessing it won't, but I will sleep better tonight at least.I don't know,I'll cross that bridge when I get to it.
