Pinion flange help
TWISTED2471
Delaware
Can anybody help me .can't figure out how to remove pinion flange,moves about 3/4 inches and stops,this is for the front axle pinion flange under the radiator.thanks
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Yes. It knocks off. Otherwise go get a jaw puller. Take the Pinion nut off. And a BFH to smack it with. Its just stuck. Hit it harder
Sent from my SM-G935P using Tapatalk
TWISTED2471
Delaware
I've. Got the flange off,I've removed the 8 bolts on the cover ,I pried it about 3/4 inches from the surface,I can spin it and the shims,I can see the seal,but nothing will budge any farther,is the a snap ring or? On the back side amongst the shims
Coffey1
497
Gray Court SC
No they are just stuck on there most likely by sealer.
Be gentle with them they bend easily.
simp5782
9,339
Mason, TN
Piece of steel. Drill 3 holes in it. 2 3/8" and one half inch. Well a nut to the half inch hole. Hook bolts to flange thru the steel. Takes about 20mins to have your own puller.
