AOR
- 23
- 18
- Burtonsville, MD.
I am planning to install a pintle extension on my M998 soon. I am hoping that someone can give me specifications on the dimensions and thickness of the plates. I did some looking around and what I found online only shows one dimension and it shows them being 5/8” thick but I do not think this is accurate based on the bolts being 5.75" long would not have enough threads to get the nuts on all the way. This is unless the pintle extension was intended to be used without the reinforcement plate for the higher towing capacity.
I am somewhat of a purist and trying to make everything as correct as possible since I have not been able to locate those plates and they look easy to make. Here is the part number from the manual - Qty 2 plate mounting 5340014077192 12342665
thank you
here is what I found online including a link to another forum with the exploded parts view #17 are the parts I am referring to
I hope I am not in any violations I was not able to figure out how to save the image and post it
Technical Data | NSN 5340-01-407-7192
thank you
Characteristic | Specifications |
MATERIAL | STEEL |
MATERIAL DOCUMENT AND CLASSIFICATION | ASTM A569 ASSN STD SINGLE MATERIAL RESPONSE |
SHAPE | SQUARE |
LENGTH | 5.250 INCHES NOMINAL |
THICKNESS | 0.625 INCHES NOMINAL |
