pioneer tool rack difference?
juanprado
3,125
Metairie/La (N'awlins)
I notice there are 2 different under the bed pioneer tool rack tray/holders part number 12340288 & 12340289.
What is the difference in them?
juanprado
3,125
I did not see that. I just saw the bracket that it nestles into on the cross member. What is the other style?
I saw both styles on ebay and trying to figure out which to buy? I have found the Kascar brackets to use with an airlift bumper upgrade I am doing to retain use of the rack.
Thanks for your help!
juanprado
3,125
the 12340288 is used for the original bumper or mwo towing upgrade.
The airlift bumper requires the 12340289 as it nestles into the diagonal inner braces.
If you have a 12340288 it can be converted easily to a 12340289 by adding 2 angle brackets $4 each from kascar. 5583234 L, 5583235 R
ElKapetan
Lancaster, OH
Hummer 4.jpgHummer 1.jpgHummer 2.jpgHummer 3.jpgJust finished adding airlift bumper to A1, now can’t get shovel to fit. Shovel blade hits the diagonal bumper braces and frame when I try to latch the rack, can’t find good pics to show how supposed to fit. Using newer rack for Airlift, standard shovel. Any suggestions?
