piston sleeve removal
1,178
tm 9-2815-210-34-2-2
1,178
Oh, you already removed it.
1,131
Holy crap-you broke it!
saddamsnightmare
80
Abilene, Texas
May 9th, 2012.
Now may not be the time to mention this to the OP, BUT there is a special tool kit for pulling Multifuel engine sleeves properly, and they often turn up on EBAY for cheap!:gimp2:
ChuckM
Brantley, AL
I pulled a pan off a deuce that looked just like that recently. That's as far as I got and just pulled the engine. The funny thing is the thing was still running. Knocking hard but still running.
I once seen an EMD sling a rod out of the side of the block and land next to my feet. It kept running until I shut it down. Engines can run under some abnormal conditions. :shock:
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Yep, looks like my M108 engine. Let us know how the bore looks. Mine blew at idle, and yes, it still ran.
m16ty
218
Dickson,TN
Sounds like there could be a pattern here. I wonder what would cause a sleeve to fall apart like that?
ken
25
Houston Texas
put it in the freezer overnitght before installing. Keep it as cold as possable untill you install it. When cold they will usall slide right in. Alot less banging if you dont have the right tools
