linhster
- 1
- 8
- Delray Beach/FL
Rebuilding the hub…. How critical is it to required the use of the plastic gasket between the input seal and the hub? Can I just use RTV silicone instead?
Assuming it's more for the pressure against the loose race of the inner bearing. How would you know how much shims (thickness) to keep?The plastic gaskets are shims, if you dont have enough shims the upper bearings can get hot
correct...the procedure is in the TM, it requires a feeler gauge.manual says its a shim and to put back what you took out.
Thanks...Might have gone overboard with the details. I am sure all seasoned members are quietly laughing at my feeble efforts.Looks really nice. I love the detail you are giving it.
