After last weeks outtage, i decided to do some general maintenance. My main concern was the mouse piss i smelled and some debris i saw.
After taking the cover off, i did find some nesting material behind the control box. Thankfully it was only a start. Most of the mess was in the center of the genset at the bottom where the drian holes are under the black foam below the engine. That is clearly the entry point.
I spent 2 hours cleaning it well. I put everything back together, and propped up the genset on wood blocks after using a leaf blower to blast the remains of the main nest out from under the genset.
Screening over the intake vents on the side will be easy, but what are you all doing to seal the bottom drain holes from mice, and yet still allowing the drain holes to function as designed?
I would appreciate any pics of what you did, for both the holes, and the sides.
I didn’t have time to check if my fuel meter was stuck in the tank, showing full all the time, and i want to change out the oil to deere break in oil. I picked this genset up with 22 hours in the meter, and changed the oil to full synthetic. It now has approx 35 hours on it. I have been meaning to change it out till 100 hours but have been lazy.
Any idead would help. Thanks.
