Please ID this trailer - thanx
oddave715
Lexington, North Carolina
Lifting rings look like the same rings I have on a marine corp trailer. And the little tires look like something from an airfield. Not much help I know but those are the things I see to start off.
robson1015
132
New Concord, Ohio
Bought this off craig's list to mount my MEP-831A onto. IMGP3011.jpgIMGP3020.jpgNeeds a new hand brake lever, this one rusted and broken inside. It uses the same hand brake as a m416 trailer. Has anyone seen this type trailer ???
robson1015
132
New Concord, Ohio
The entire trailer is aluminum including the lunette ring. Tire on the nose is 4.10/3.50/6 The rear tires are 6.90-9NHS
I found some faint numbers stamped on the side 305 ASSY 83 14463 Anyone ???
quickfarms
22
Orange Junction, CA
The rear tires are common to airfield support trailers.
The trailer looks like it was once some sort of aircraft support trailer. It is designed for low speed off highway use.
quickfarms
22
Orange Junction, CA
Would it be possible to use on the highway with the proper tires???
Anything is possible a lot depends on the weight distribution and if it is top heavy with the generator.
Personally I hate trailers that are narrower than the towing vehicle.
Are you talking around town or on the freeway?
Does it have a suspension?
The tires are an old trailer size.
Does your state require brakes on a trailer?
You would have to add lights
robson1015
132
New Concord, Ohio
It has torsion suspension and is 5 feet wide to the center of the wheels. With lights and road tires it seems it would be road worthy. I doubt I would take it out on the interstate but it is well built. Wouldn't require brakes being so light even with a 300 lb. generator on board. Thanx for the reply.
