- 1,172
- 31
- 48
- Galesville, WI
Mine has heavy weight oil. Hard shifter. I hear some owners see smoother shifts and an increase in leaks when going to ATF. Sounds reasonable to me.
I believe it was Plowboy who suggested downloading the manual and setting the transmission adjustments. I would definitely do this first!
As far as a torque converter the answer is more or less yes. It is called a torus. I understand a torque converter is a contained unit with torus inside. Your torus is formed by a housing bolted to the flywheel that directs the fluid flow much like a torque converter.
