If the radiator is on you r right, it goes the closest cylinder to the fan is 1, then 2, and so on threw 6. And if you look at the casing of you distributor as a rectangle, and on the right side, upper right corner next to the screw, is your number 1. Then going clock wise, the next is 4, then 2, then 6, then 3, then 5, and then back to 1. Ive got the Kaiser Jeep Model 6-230 140 HP Data sheet for everything from ignition, distributor, vacuum, alternator, and all kinds of other jazz. Its just one sheet, front and back. Send me you email address, and ill scan it for ya, and email it to you.
Nate.
Nateotto@mindspring.com
