Plug wire diagram for -715?
maddawg308
781
Appomattox, VA
Anyone got a plug wire diagram for the -715 series? I can't find anything in the manuals I got for my rig, and want to make sure I hook up the wires in the right firing order.
Knottofs
White Level, NC
If the radiator is on you r right, it goes the closest cylinder to the fan is 1, then 2, and so on threw 6. And if you look at the casing of you distributor as a rectangle, and on the right side, upper right corner next to the screw, is your number 1. Then going clock wise, the next is 4, then 2, then 6, then 3, then 5, and then back to 1. Ive got the Kaiser Jeep Model 6-230 140 HP Data sheet for everything from ignition, distributor, vacuum, alternator, and all kinds of other jazz. Its just one sheet, front and back. Send me you email address, and ill scan it for ya, and email it to you.
Nate. Nateotto@mindspring.com
maddawg308
781
Appomattox, VA
Revisit here - just want to make sure its right before I blow the block up. It probably will anyways. :)
Anyways, here's a couple pics of the distributor. Nate, I heard that the firing order was 1-6 going counterclockwise. Can anyone shed light on this?
Knottofs
White Level, NC
Humm! That didn’t work. let me try something else. Im having a problem getting the images pixels down to below 640. Anybody got any ideas on how to do that?
