wsucougarx
- 65
- 48
- Washington State
Hello gentlemen. A couple weeks ago I took my M109A3 out on the road. I was a mere 3 miles from the house and noticed the temp gauge was pegged (240 degrees +). I drove her home and cooled her down. The temp was hovering around 160 after 2 hours of cooling. I was thinking it was a closed thermostat so I went to NAPA and bought a 180 degree thermostat. I decided to flush the system, replaced all the 2 inch coolant hoses, and the upper/lower radiator hoses.
Today I went out to do the final flush with the thermostat in. I filled the system up with distilled water only. I noticed the temp gauge climbed upto 220 and looks like it would keep going. I shut her off. I decided to drain off the final flush water. The initial water coming out the radiator petcock was cold (same temp as what I put in initially). The top of the radiator was warm, but the lower portion was the same as the outside temp. I continued to drain off about 2 gallons and then the water started to get warm and then hot. So, is this a good indicator of a plugged radiator? It appears the radiator is what came with the truck. It is the old green painted radiator rather than the newer all black ones. Please advise. Is there anything else I've missed? The water pump turns freely.
Yes I did do a search
