PN for bulk hose for oil pump to oil pan lines for Cummins 855 NTC 250
LCA078
60
Austin, TX
I’m looking for bulk oil hose and searched all over here and the web but can’t find a part number or other descriptive way to explain to my local industrial hose shop what I need to replace my oil pump hoses. Not having luck with the local truck repair shops either. Was hoping to reuse the fittings but I understand the reusable fittings are pretty sensitive to the OD of hose, thus the concern for an exact fit.
And yes, I over worded the title to make it more searchable for others
simp5782
Feo, Fuerte y Formal
9,260
Mason, TN
Have a hydraulic shop make them. It's just easier the oil pan side on the suction hose is a parker triple thread fitting. Around $60 a hose. This is a fitting that you don't want to Leak. Reusable fittings are nice but they do have their weak links
LCA078
60
Austin, TX
Thanks, Wes. This is one of those 'yes buts'
I don't have access to the truck except on random weekends and my local hydraulic shops are closed on weekends. I don't have an easy way to take the old hoses to a hydraulic shop to copy on a one day turn. I understand I'll also need new fittings from a few threads about these oil hoses but again, I'll have rip it apart and then go shopping. So who knows how long before I'll get all the correct parts.
My current hoses are wet but not dripping so it's not an deadline issue. Was just hoping to have a complete service job next time I change oil and filters.
So yes, making custom hoses is best...but, I was hoping to make it a simple 30 min job with just using bulk hose.
